DIY Interior Door Fabric and More....
Well-known member
Just a quick DIY guide on this easy mod :)
Remove all your door panels and when you remove the rug it's a plastic material.
You can use any fabric pretty much. Use fabric glue to make it stick :)
You can try to cut the material to the shape you need but that's going to be impossible. I laid the material over it and will use a very sharp blade to cut the material.
You really need to get the corners good! But don't use too much glue or it will soak through!
Now just do more things :)
Cheers!
I need to do this to a few vehicles I have out back. It doesn't look like it's too hard to do. Thank you for the share!
No problem. The hardest part is cutting the material after glued. Helps to use a paint scraper, while pushing it down in the edge and cutting on the other side of it for a straight cut. The edges, ya just doing it by hand. Long ago I seen people use rope to fill any imperfections.
Example: I tried smaller rope for the longest time, was ok.
